Remove acknowledgements and enable notifications
emartine
Post by emartine »
We keep getting "nagios failing to notify us" because individuals are supressing alerts by acknowledging them in some for or another. Is there a way to create a weekly purge of acknowlegements and enable notifications ?
npolovenko
Re: Remove acknowledgements and enable notifications
Post by npolovenko »
Hello, @emartine. One way to get rid of all acknowledgments is to delete the retention.dat file.
/usr/local/nagios/var/retention.dat
So you could create a simple shell script that removes this file and put it in a cron.
PS: Deleting the retention.dat file will also delete all scheduled downtime and comments.
emartine
Post by emartine »
Meaning if it is active now that it will remove currently active scheduled downtime? Or it will remove any future scheduled downtime windows?
npolovenko
@emartine, It will remove all existing downtime records, whether downtime was scheduled for now and already started or if it's scheduled for some time in the future.
emartine
Post by emartine »
Is there a way to reimport those schedules in bulk?
npolovenko
@emartine, This sequence of commands worked for me do delete all acknowledgments without affecting scheduled downtime:
service nagios stop
sed -i "s/problem_has_been_acknowledged=1/problem_has_been_acknowledged=0/g" /usr/local/nagios/var/retention.dat
service nagios start
Please backup your XI before trying this.
emartine
Post by emartine »
This does remove the acknowledgements but doesn't seem to enable notifications.
npolovenko
@emartine, Can you run the same query with enable_notifications=1?
service nagios stop
sed -i "s/enable_notifications=0/enable_notifications=1/g" /usr/local/nagios/var/retention.dat
emartine
Post by emartine »
I think you mean notifications_enabled=1 ?
emartine
Post by emartine »
I created a dashboard with a urldashlet
and although the page looks fine... when I have a report sent only the top part of the pdf is visible while the rest is blank.
Any idea why or what I can do to fix this?
The url dashlet I created was https://servername/includes/components/ ... viceattr=4
