nagios.cmd changes
onegative
nagios.cmd changes
Post by onegative »
G 'Day Nagios XI Support,
I am running into situations where my nagios.cmd file is changing from a pipe to a regular file.
What could cause such a change in the file? How do I troubleshoot this issue? Once it occurs then setting up Scheduled Downtimes seems to have trouble and I am forced to restart nagios core manually.
Any suggestions?
Leave on Friday
[root@dcom-nagiosxi-p1 rw]# ll
total 0
prw-rw---- 1 nagios nagcmd 0 Mar  1 07:06 nagios.cmd
srw-rw---- 1 nagios nagcmd 0 Mar  1 07:04 nagios.qh
Return on Monday
total 4
-rw-r--r-- 1 nagios nagcmd 136 Mar  4 05:01 nagios.cmd
srw-rw---- 1 nagios nagcmd   0 Mar  4 05:00 nagios.qh
Let me know and thanks,
Danny
Re: nagios.cmd changes
Do you have any scripts that write commands directly to the nagios.cmd ?
Do you have your XI server setup to receive SNMP Traps?
onegative
Post by onegative »
Hey Scott,
No I do not have any external scripts writing to the pipe.
Yes I do have snmp traps using snmptt enabled but not utilizing it in any production manner. There might be some traps being sent to the server but unsure.
[nagios@dcom-nagiosxi-p1 ~]$ ps -ef | grep snmptt
root      5383     1  0 10:48 ?        00:00:00 /usr/bin/perl /usr/sbin/snmptt --daemon
snmptt    5384  5383  0 10:48 ?        00:00:00 /usr/bin/perl /usr/sbin/snmptt --daemon
nagios   12011 30673  0 12:03 pts/0    00:00:00 grep --color=auto snmptt
[nagios@dcom-nagiosxi-p1 ~]$ grep snmptt /etc/group
nagios:x:20954:apache,nagios,snmptt
nagcmd:x:20961:apache,nagios,snmptt
snmptt:x:989:
Can you run the following and show the results
grep nagios.cmd /usr/local/bin/snmptraphandling.py
onegative
Post by onegative »
[root@dcom-nagiosxi-p1 rw]# grep nagios.cmd /usr/local/bin/snmptraphandling.py
        if os.path.exists('/usr/local/nagios/var/rw/nagios.cmd') and stat.S_ISFIFO(os.stat('/usr/local/nagios/var/rw/nagios.cmd').st_mode):
                output = open('/usr/local/nagios/var/rw/nagios.cmd', 'w')
That looks like it is supposed to.
Hmm, this is a bit of a mystery, usually this happens if something tries to write to the file in a brief time when the nogios process isn't running.
How frequently are you seeing this?
onegative
Post by onegative »
Often...I wonder if this is happening when someone is trying to a Scheduled Downtime while someone else is making a configuration change?
ssax
Dreams In Code
Post by ssax »
You don't have any cron jobs or anything running on the backend that do any sort of automated host management or use any of the external commands, correct? Or any custom event handlers or anything?
See here for examples:
https://assets.nagios.com/downloads/nag ... ernalcmds/
That snmptraphandling.py is the usual culprit in this but since yours has the S_ISFIFO, it is not the issue.
Do you use NRDP for passive checks at all?
onegative
Post by onegative »
I have no cron jobs that perform any type of host mgmt or external commands especially to the nagios.cmd file.
My environment is nearly all passive monitoring using the NCPA agents on remote hosts...sending their results to the NDRP API on the Nagios XI Server.
npolovenko
Post by npolovenko »
@onegative, What is the output of:
ls -l /usr/local/nagios/var/
How often does it take from the moment you restart the nagios service till the cmd file gets overridden with incorrect permissions? On the second screenshot, I see that both files: nagios.cmd and nagios.qh were modified at 5 am. Was there any security scan running at that time or anything else you could think of?
Try restarting the Nagios process and then Apply configuration in the GUI and let me know if that changes permissions on the cmd file?
Also, please check how much time passes before the permissions change again?
