Total Warnings: 953
Total Errors: 0
> Return Code: 0
Stopping nagios: .done.
Starting nagios: done.
Stopping httpd: [ OK ]
Starting httpd: httpd: Could not reliably determine the server's fully qualified domain name, using XXX.domain.com for ServerName
[ OK ]
No entry for terminal type "unknown";
using dumb terminal settings.
Nagios XI Upgrade Complete!
We are aware of this issue and this may happen when a file has changed on the system during the upgrade process. If go to the home page then back to Admin > Check for Updates, it should be reporting that your system is up-to-date ( and was updated successfully ).
If you like, you can upload the log file /usr/local/nagiosxi/tmp/upgrade.log, and I can review the log.
