EMC script and disk fracture
Has any one experienced any issues with the emc script causing problems while a disk fracture is running?
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: EMC script and disk fracture
Apologies. The script is
EMC CLARiiON
Monitor an EMC CLARiiON SAN.
Version: 2011-07-18, Author: Troy Lea aka Box293
we are running nagios xI version 2011 r2.1
EMC CLARiiON
Proudly running:
Nagios Fusion
Nagios Fusion
I haven't used these but it may help if you could describe the type of problem you are experiencing, and others may chime in with similar experience.
