Extract data of monitored server
anilgupta
Post by anilgupta »
Team,
We are looking to extract performance data of the monitored servers.
We would like to push it to our Central Data Repository (CDR) and generate monthly/quarterly reports.
I understand that this data is stored in RRD.
What are the options to fetch this data?
cdienger
Re: Extract data of monitored server
Post by cdienger »
The rrd files are stored in /usr/local/nagios/share/perfdata/<hostname>/ and you can copy the files from there or you can use the API to export the rrd data. API options are available under Help > REST API Docs > Objects Reference.
anilgupta
Post by anilgupta »
Hello cdienger,
Thanks for your response. I am trying the curl from the same server, still it takes around 40 seconds and finally throws HTTP code 504.
Can you please comment on this?
[guptaa@pstvmpkimon02 ~]$ hostname -i
fe80::20c:29ff:feba:1509%ens192 192.168.0.162 192.168.122.1
[guptaa@pstvmpkimon02 ~]$ date;curl -XGET "https://192.168.0.162/nagiosxi/api/v1/objects/hoststatus?apikey=SANITIZEDTEXTVALUE&pretty=1"; date
Wed Mar  6 09:14:17 EST 2019
curl: (56) Received HTTP code 504 from proxy after CONNECT
Wed Mar  6 09:15:32 EST 2019
cdienger
Post by cdienger »
Run the command so that it doesn't go through a proxy. Try adding the following to the curl command:
--noproxy 192.168.0.162
anilgupta
Post by anilgupta »
It works, Thanks cdienger!!!
cdienger
Post by cdienger »
Glad to hear! Are we okay locking this one up?
