I have latest version of Nagios Community.
I have servers and lots of routers.
Server and router configurations are in different cfg files (windows.cfg and network.cfg)
Is there any way to separate server logs and routers logs in different log files? If possible can you give me a little example?
Regards,
Different log files
Re: Different log files
No, there is only one nagios.log file and no configuration for another.
It is possible to add these servers into multiple hostgroups and then use the builtin reporting filtering by hostgroup, for example in the availability report.
