I got the following error from weblogic I would like to filter with the pattern "DeregisterTruckDto' - java.lang.ClassCastException"
2019-03-06 15:09:03,431 agement.service.dto.DeregisterTruckDto' - java.lang.ClassCastException@757bae24 - had objects of type "java.lang.String" but expected signature "java.lang.Lo
ng"
What criticalexception should I add?
DeregisterTruckDto .* java.lang.ClassCastException .* <---??
check_logfiles filtering
Re: check_logfiles filtering
I believe you should be able to make a query on the dashboard that has the following that should catch these
DeregisterTruckDto AND java.lang.ClassCastException
