How can I pull CSV file to XI graph?
dimsum
Post by dimsum »
Maybe I have columns with IP, Byte of traffic and I need to plot a graph from my CSV file. Do you have any suggestion for the solutions?
Thank you.
cdienger
Re: How can I pull CSV file to XI graph?
Post by cdienger »
XI probably is not the best solution for this since it graphs data from plugin results(https://assets.nagios.com/downloads/nag ... fdata.html) and not from importing files. This would be better suited for our NLS product.
