Nagios Application and Network Monitoring using Nagios Core
kaushalshriyan
Post by kaushalshriyan »
I am running Nagios Core 4.4.3. Is there a way to do both Application and Network Monitoring using Nagios Core?
#/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.4.3
Last Modified: 2019-01-15
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
	Checked 333 services.
	Checked 42 hosts.
	Checked 1 host groups.
	Checked 0 service groups.
	Checked 30 contacts.
	Checked 6 contact groups.
	Checked 36 commands.
	Checked 5 time periods.
	Checked 0 host escalations.
	Checked 42 hosts
	Checked 0 host dependencies
	Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
Thanks in Advance.
Best Regards,
Kaushal
steffi
Re: Nagios Application and Network Monitoring using Nagios C
Post by steffi »
Yes, it is possible.
For applications you are able to check for an existing process, have a look at check_process plugin.
benjaminsmith
Post by benjaminsmith »
Thanks @steffi.
You can also search the Nagios Exchange for more plugins.
Let us know if you have any other questions.
kaushalshriyan
Hi Steffi and Benjamin,
Thanks for the quick reply and much appreciated. How about Network Monitoring? Is it possible with Nagios Core 4.4.3?
Thanks in Advance
Best Regards,
Kaushal
benjaminsmith
Hi @kaushalshriyan,
Yes, that's possible. Take a look at the check_snmp plugin documentation here:
check_snmp
https://www.monitoring-plugins.org/doc/ ... _snmp.html
Nagios Plugins
https://assets.nagios.com/downloads/nag ... ugins.html
