We have a Nagios server with Nagios XI 5.3.3 and RedHat 6.8
We want to install a new server with Centos7.6 and the latest Nagios version.
Is it possible to get the configuration from old server and put it on the new one?
Or do we have to upgrade the old server to the latest Nagios version and then get it and put it at the new one? if yes is it possible to upgrade 5.3.3 to latest version?
Thank you
Nagios backup configuration and load it on a new server
nms_system_support
Re: Nagios backup configuration and load it on a new server
I would highly recommend updating the old server to the latest, take a backup and then restore on the new server
nms_system_support
Let us know if you need further assistancenms_system_support wrote:Thank you!
