What is wrong with my plugin N
pcouderc
Post by pcouderc »
Here is a working pluging called by NRPE ;
#!/bin/bash
    echo "CRITICAL-pc "
    exit 1
It works either on the client either on the nagios server.
Here is a non working plugin:
#!/usr/bin/perl
print STDERR "CRITICAL-pc\n ";
exit(1);
This works fine on the client but on the server, it gives me back : NRPE: Unable to read output
Everything is identical : same directory , owner and rights : -rwxrwxrwx
What do I miss ?
Thanks for any idea.
Re: What is wrong with my plugin N
You need to print to STDOUT, change to this
#!/usr/bin/perl
print STDOUT "CRITICAL-pc\n ";
exit(1);
Also, just as an FYI, the exit code for CRITICAL should be 2 not 1, 1 is WARNING, so
#!/usr/bin/perl
exit(2);
