check_udp | openVPN | --send | --expect
steffi
Post by steffi »
Hi.
I like to check if my openvpn server is running correctly.
When running check_udp, the script is complaining about a send or a expect String which is missing.
I guess this check is used quite often. Does anybody know what to submit as an argument for --send or --expect?
I tried --expect '1194' based on the following command, but with no success.
root@fw-2018:~# nc -vz -u localhost 1194
Connection to localhost 1194 port [udp/openvpn] succeeded!
Steffi
ssax
Dreams In Code
Re: check_udp | openVPN | --send | --expect
Post by ssax »
What is the output of this command?
/usr/local/nagios/libexec/check_udp -H OpenVPNIP -p 1194 -s '$38$01$00$00$00$00$00$00$00' -e '' -v
You may want to take a look through these other OpenVPN plugins:
https://exchange.nagios.org/index.php?o ... rd=openvpn
steffi
Post by steffi »
Hi.
Thanks for your input. This is the output:
root@fw-2018:~# /usr/lib/nagios/plugins/check_udp -H 127.0.0.1 -p 1194 -s '$38$01$00$00$00$00$00$00$00' -e '' -v
Using service UDP
Port: 1194
flags: 0x2
Send string: $38$01$00$00$00$00$00$00$00
server_expect_count: 1
        0:
CRITICAL - Socket timeout after 10 seconds
OpenVPN server is up and running on all ports and working fine.
Steffi
steffi
Post by steffi »
Hi.
I switched to this check, which is working fine:
check_udp_port
Thank you for your support.
Steffi
ssax
Dreams In Code
Post by ssax »
That's great to hear, thanks for the update! Are we okay to lock this up and mark it as resolved?
