Import problem
Bitflogger
Import problem
Post by Bitflogger »
Hello, I am running 5.5.10 when the problem occurred, I have since upgraded to 5.5.11. 64-bit, VM, CentOS7
I have imported my production configuration to my test server.
Excluded hosts and host groups in services become objects of the same name, with a "!" as the first character, and are not active.
The !* objects are in the expected lists of the services, but are not excluded.
Somehow the configuration apply function returns normal.
Earl
Re: Import problem
Exclusions with "!" cannot be imported. It's stated in our official documentation.
Bitflogger
Re: Import problem
Is that fundamentally impossible, or no one has had the time to do it yet?
Earl
jomann
Development Lead
Re: Import problem
Post by jomann »
It's not impossible, but the reason it works like that right now is that previous versions of the CCM did not have the ability to use excluded objects. I made a note for this and will take a look into it, including a feature request and possibly get this in to the next minor release depending on the complexity.
Bitflogger
Re: Import problem
OK, Thanks!
Please lock the call.
Earl
