mysql.sock
jatindeepsharma
mysql.sock
As i am getting error as
/usr/libexec/mysqld: Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed
i have tried to repair this table several times but i is getting crashed again .
I have checked size of this table & it is about
/home/mysql/mysql/nagios
12K nagios_logentries.frm
92G nagios_logentries.MYD
65G nagios_logentries.MYI
i want to truncate these tables after bacup it up. but when i am truncating it. i am getting error as permission denied for mysql.sock.
this file is having sudo rights,how can i change those rights?
srwxrwxrwx 1 mysql mysql 0 Mar 12 09:57 mysql.sock
thanks
JD
thanks
JD
Re: mysql.sock
These seemed like the correct permissions... What happens when you run the command below?
Does it work for you?
mysql -u ndoutils -pn@gweb nagios -e 'TRUNCATE TABLE nagios_logentries'Be sure to check out our Knowledgebase for helpful articles and solutions!
jatindeepsharma
Re: mysql.sock
Hello Dear
Sorry for late reply.. yes i have tried this command... but it is giving me output as:
ERROR 1045 (28000): Access denied for user 'ndoutils'@'localhost' (using password: YES)
Re: mysql.sock
you would need to change the password to the password you see when running this command
grep ndoutils -5 /usr/local/nagiosxi/html/config.inc.php |grep pwd-
jatindeepsharma
Re: mysql.sock
Hi scottwilkersonscottwilkerson wrote:you would need to change the password to the password you see when running this commandCode: Select all
After running above command, i am getting output as:
[root@NagiosSQL ~]# grep ndoutils -5 /usr/local/nagiosxi/html/config.inc.php |grep pwd
grep: /usr/local/nagiosxi/html/config.inc.php: No such file or directory
jatindeepsharma
Re: mysql.sock
but when i am running same command on nagios i am getting output as :jatindeepsharma wrote:Hi scottwilkersonscottwilkerson wrote:you would need to change the password to the password you see when running this commandCode: Select all
[root@NagiosXI nagiosxi]# grep ndoutils -5 /usr/local/nagiosxi/html/config.inc.php |grep pwd
"pwd" => 'xxxxxx',
Re: mysql.sock
Where else were you running the command? It's supposed to be run on the Nagios XI server......but when i am running same command on nagios i am getting output as :
If the password 'xxxxxx' is different than "n@gweb", use it in the command that was previously run:[root@NagiosXI nagiosxi]# grep ndoutils -5 /usr/local/nagiosxi/html/config.inc.php |grep pwd
"pwd" => 'xxxxxx',
mysql -u ndoutils -p'xxxxxx' nagios -e 'TRUNCATE TABLE nagios_logentries'Be sure to check out our Knowledgebase for helpful articles and solutions!
Re: mysql.sock
One more thing - if your mysql is offloaded to a remote server, you would need to run the command on the mysql server. You could also run it on the Nagios XI server as such:
Make sure that the actual username is still "ndoutils". It's possible that you changed it to "nagios" if you followed this document:
https://assets.nagios.com/downloads/nag ... Server.pdf
It's always a good idea to repair the db after truncating a table, so you could run (on the offloaded server):
Hope this helps.
mysql -h <ip address of the offloaded mysql server> -u ndoutils -p'xxxxxx' nagios -e 'TRUNCATE TABLE nagios_logentries'https://assets.nagios.com/downloads/nag ... Server.pdf
mysqlcheck -r -f -uroot -pnagiosxi --all-databasesBe sure to check out our Knowledgebase for helpful articles and solutions!
jatindeepsharma
Re: mysql.sock
actually my username & password for SQL is nagios but when i am running given command on nagios sql or on nagios, i am getting below output.lmiltchev wrote:One more thing - if your mysql is offloaded to a remote server, you would need to run the command on the mysql server. You could also run it on the Nagios XI server as such:
Make sure that the actual username is still "ndoutils". It's possible that you changed it to "nagios" if you followed this document:Code: Select all
It's always a good idea to repair the db after truncating a table, so you could run (on the offloaded server):Hope this helps.Code: Select all
mysql -h <10.200.1.152> -u nagios -p nagios nagios -e 'TRUNCATE TABLE nagios_logentries' -bash: 10.200.1.152: No such file or directory
Re: mysql.sock
Try:
from the Nagios XI server or ssh into the offloaded mysql server, and run the command locally:
mysql -h 10.200.1.152 -u nagios -pnagios nagios -e 'TRUNCATE TABLE nagios_logentries'Code: Select all
mysql -u nagios -pnagios nagios -e 'TRUNCATE TABLE nagios_logentries'Be sure to check out our Knowledgebase for helpful articles and solutions!
