How to delete nagiosxi service using API ?
sac1472
Post by sac1472 »
Hello, i have commands to delete nagios service using API. it works well for serivces which doesn't contains space in name. & doesn't work with space.
Please check attached screenshot --
cdienger
Re: How to delete nagiosxi service using API ?
Post by cdienger »
Use %20 for the space ie Physical%20Memory.
