ERROR: Process name table : Message size exceeded buffer max
trungleviet
Post by trungleviet »
Dear All;
When i tried to add a new hosts on NagiosXi; when i selected to see the services status running on that hosts, i seen this error
ERROR: Process name table : Message size exceeded buffer maxMsgSize.
Could you please help me to fix this problem; i am a new beginner.
Many thanks all,
Trung Le Viet
Re: ERROR: Process name table : Message size exceeded buffer
By chance is this using the Windows SNMP Wizard?
In case it is, I am attaching a new check_snmp_win.pl that has a vastly increased max table size, yo can modify yours by going to Admin -> Manage Plugins and uploading it there.
trungleviet
Many thanks for your reply, Scottwilkerson.
I done like your instructions and it work well with me.
Another question: I am using NagiosXi and i want to detect all installed softwares on user workstation. Could you advice me how to do that. Can I use Auto Dicovery Wizard to do this?
Thanks you very much, Scottwilkerson.
Wish Best Regards,
Trung Le Viet
Asked and answered in your other post
http://support.nagios.com/forum/viewtop ... f=6&t=5301
