Issue with check_init_service plugin
bsivavani
Post by bsivavani »
We are trying to monitor kafka-manager service using check_init_service plugin and kafka-manager service available in /etc/init.d/kafka-manager
When we check the status of service, we are getting service is in stopped state even though it is running at backend and getting the same message in Nagios console.
[root@XXXX libexec]# service kafka-manager status
kafka-manager is not running.
Kindly advice ?
cdienger
Re: Issue with check_init_service plugin
Post by cdienger »
Do you see it running if you run:
/bin/systemctl is-active kafka-manager
One other thing to consider is it may be starting via a different method outside of an init script. I
bsivavani
Post by bsivavani »
We are RHEL 6 server.
Systemctl is RHEL 7 command.
cdienger
Post by cdienger »
Ticket received. Closing thread.
