Plugin check : check_service.sh
liberodark
Post by liberodark »
I wanted to submit this plugin on which I worked a little to have your feedback on the quality of the plugin?
https://github.com/jonschipp/nagios-plu ... service.sh
Best Regards
Re: Plugin check : check_service.sh
I saw your other post where you added the entries to the sudoers files, and fixed the selinux issue in the systems.
Is the plugin fully functioning for you now?
liberodark
Have fixed the problem with a rule on SELinux thank you for your reply
Thanks for replying back that the issue is resolved. I will lock the post for you but feel free to open a new one in the future for any other questions.
