install or move Nagios XI to different file systems
Francesco
Post by Francesco »
Dear support,
the internal support team of OS wants to separate applications on different file systems.
In this moment we are using an "Offline Installation" with RPM on RedHat 6.
Can you list all folders used by the RPM files you provide in the tarballs?
Will we need several file systems for every location or can we use symbolic links?
Can we modify the actual installation or we have to make a new installation and then restore the configuration?
Will you support this kind of installation?
We wait your feedback
Thank you for your attention
benjaminsmith
Re: install or move Nagios XI to different file systems
Post by benjaminsmith »
Hi @Francesco,
This is not something we recommend or officially support. This is probably best done using symbolic links, but in the event you have issues with installers or other scripts we may not be able to resolve your problem.
