I have some hosts in monitoring nagios. After I've enabled monitoring, after a few hours the hosts begin to disappear from the panel and the configuration files as well. Any idea?
Thanks in advance.
hosts disappear
benjaminsmith
Re: hosts disappear
Hi @egas84,
This type of behavior can occur when there are multiple Nagios processes at the same time. Run the following from the command line.
Let me know if that takes care of the issue.
service nagios stop
killall -9 nagios
service nagios restart
Re: hosts disappear
Hi @benjaminsmith,benjaminsmith wrote:Hi @egas84,
This type of behavior can occur when there are multiple Nagios processes at the same time. Run the following from the command line.Let me know if that takes care of the issue.Code: Select all
service nagios stop killall -9 nagios service nagios restart
Thanks for your answer.
I have listed my processes and see only one process.
Anyway, I finished the process and it did not work.
benjaminsmith
Re: hosts disappear
Hi @egas84,
In most cases, this is caused by multiple Nagios processes running. The configuration files/settings should not disappear from your server. Are using some sort of configuration management software to automate configuration?
Also, what browser are you using? Can you confirm the behavior from another browser?
