Hi!
We recently implemented a new product, Palo Alto Network's TRAPS security system. This system is now blocking almost all of our NRPE traffic because it sees it as a reverse-shell exploit.
Is this a known issue? Any workarounds or config changes we should make to get this working? We are trying to get them to add exceptions but the security team says that there isn't a way to whitelist this traffic without making exceptions for each of our thousand monitors (not sure how sincere that statement is, but it is all I have to work with)
Any help is greatly appreciated!
-- josh
NRPE requests getting blocked by Palo Alto TRAPS security pr
Re: NRPE requests getting blocked by Palo Alto TRAPS securit
This would be the first time I've hear about this. Is it triggering based on the actual communication or simply on port? If it's the actual traffic that it is triggering on, then one option that could work would be to encrypt the traffic: https://support.nagios.com/kb/article/n ... y-519.html and with nsclient I believe you just need to edit nsclient.ini to contain:
[/settings/NRPE/server]
ssl options = no-sslv2,nosslv3
use_ssl = 1As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
