Would someone with Nagios XI installed test to see if NagiosTV is compatible?
https://nagiostv.com/
Chris
Does NagiosTV work on Nagios XI?
Re: Does NagiosTV work on Nagios XI?
Looks pretty cool and seems to work
The only thing I had to do differently for the setup was moving the nagiostv directory to /var/www/html/ instead of /usr/local/nagios/share/
Thanks! I updated the installation instructions with that info
Sounds goodtelix wrote:Thanks! I updated the installation instructions with that info
