Hi.
I have a script I want to run at Core startup.
It is a socket listener that I want started with Core and run the whole time Core is active.
Where is the best place to put the script execution?
Thanks, Rick
Run a script at Core Startup
Re: Run a script at Core Startup
About the best I can suggest would be to modify the init script (orsystemd service file) to load your script and kill it when nagios stops.
There is no mechanism in Core directly to start and stop scripts like this.
Thanks for the reply.
That would be fine but I see no orsystemd file
Depending on the OS you are running it usually is in /etc/init.d/nagios or /usr/lib/systemd/system/nagios.service
Hi.
I meant to get back to you a while ago.
This worked great.
Thanks for your help!
Rick
This worked great.
Rick
No problem.grenley wrote:Hi.
This worked great.
Rick
Locking thread
Glad to hear!
