Contacts/email configuration
LibrarianJoe
Post by LibrarianJoe »
I'm trying to configure Nagios Core to send me emails when the services and hosts go down. I've set up sendEmail, and I think all the values in the contacts and commands config files are correct, but it's not working so presumably I'm missing something.
Here is my contact definition:
define contact {
   contact_name nagiosadmin
   use          generic-contact
   alias        librarysysadmin
   email        [email protected]
Here is the host email notification command:
    command_name    notify-host-by-email
   command_line      /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/local/bin/sendEmail -s $USER7$ -xu $USER9$ -xp $USER10$ -t $CONTACTEMAIL$ -f $USER5$ -l /var/log/sendEmail -u "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" -m "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n"
And the service email notification command:
    command_name    notify-service-by-email
    command_line   /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$" | /usr/local/bin/sendEmail -s $USER7$ -xu $USER9$ -xp $USER10$ -t $CONTACTEMAIL$ -f $USER5$ -l /var/log/sendEmail -u "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" -m "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$"
What am I missing?
Thanks much,
Joe
Re: Contacts/email configuration
Did you add the contact to a Host or Service configuration and enable Notifications for those Host and Services?
Here are a few examples you can look at.
define host {
    host_name         localhost
    use               linux-server
    alias             localhost
    address           localhost
    contacts          nagiosadmin
    register          1
    host_name                       localhost
    service_description             Current Users
    use                             local-service
    check_command                   check_local_users!20!50
    register                        1
Did you check to see if Notifications are enabled in the Nagios Web interface under the System > Process Info menu?
For more details, take a look at this link.
npolovenko
Post by npolovenko »
@LibrarianJoe, Can you also upload the /usr/local/nagios/var/nagios.log in this thread?
LibrarianJoe
Sure thing, attached.
nagios.log
(299.48 KiB) Downloaded 499 times
Your log file shows this
[1553709866] wproc:   stderr line 01: /bin/sh: 1: /usr/local/bin/sendEmail: not found
are you sure this file exists?
ls -l /usr/local/bin/sendEmail
LibrarianJoe
Ok, fixed the /usr/local/bin/sendEmail, the one that really exists is /usr/bin/sendEmail.
Also fixed the email to reflect the Gmail STMP configuration, which I forgot to fix.
Have added in the contact stuff in the host definition on a test machine, still no notification. What else should I try?
LibrarianJoe wrote:Ok, fixed the /usr/local/bin/sendEmail, the one that really exists is /usr/bin/sendEmail.
The first thing I would suggest is trying the command from the command line (replacing the variables with the real values) to verify it works
LibrarianJoe
Thanks, tried that and am having issues connecting to the gmail stmp, which I'm assuming is not a Nagios issue? Will report back if there are further difficulties once I get it to connect.
LibrarianJoe wrote:Thanks, tried that and am having issues connecting to the gmail stmp, which I'm assuming is not a Nagios issue? Will report back if there are further difficulties once I get it to connect.
Sounds good!
LibrarianJoe
Ok, got sendemail to work with gmail, but still no luck running the notification command. Here's what it currently looks like, post-tinkering to make it match my working example gmail test email:
/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/sendEmail -s stmp.gmail.com:587 -xu [email protected] -xp PASSWORD -o tls=yes -t [email protected] -f [email protected] -l /var/log/sendEmail -u "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" -m "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n"
What am I missing?
