rsyslog with filenames
BanditBBS
Post by BanditBBS »
So, this is my config file for rsyslog for the files I am sending to Nagios Log Sevrer:
$ModLoad imfile
$MaxOpenFiles 11000
$InputFilePollInterval 10
$WorkDirectory /var/imfilestate
# Input for FILE_PATH
$InputFileName /ofsh_prod/hdfs/ofsllprd/logs/*.log
$InputFileTag RDN
$InputFileStateFile nls-state-RDN # Must be unique for each file being polled
$InputFilePersistStateInterval 20000
$InputRunFileMonitor
# Forward to Nagios Logserver and then discard.
if $programname == 'RDN' then @@xxxxxxxx.com:5544
if $programname == 'RDN' then ~
I want to add a field to data adding the filename which is available via metadata for imfile in rsyslog. I've been reading for days on trying to do it and just can not wrap my head around it, especially since my config files look completely different than the sames I am seeing online.
Has anyone used rsyslog with wildcards and modified the data to include a filename field?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
cdienger
Re: rsyslog with filenames
Post by cdienger »
What version of rsyslog is on the sending machine? Rsyslog does have an option called "addmetadata" that can be used with the input module to add the file name, but it looks like it's available only in newer rsyslog 8 versions.
https://www.rsyslog.com/doc/master/conf ... ddmetadata
https://www.rsyslog.com/using-the-text- ... ut-module/
Here is what I came up with once when having to set this up:
module(load="imfile" PollingInterval="10")
input(type="imfile" file="/inputfile" tag="tag1:" severity="info" facility="local0" addMetadata="on")
template (name="LongTagForwardFormat" type="string"
string="<%PRI%>%TIMESTAMP:::date-rfc3339% %HOSTNAME% %syslogtag% %$!metadata!filename% %msg%")
action(type="omfwd" Target="192.168.55.3" Port="10514" Protocol="tcp" Template="LongTagForwardFormat")
cdienger
Post by cdienger »
You can also use wildcards with this type of config
input(type="imfile" file="/directory/*.log" tag="tag1:" severity="info" facility="local0" addMetadata="on")
