Nagios XI Install/Upgrade issues
hbouma
Post by hbouma »
We have Red Hat 7.6 64bit VM's for our Nagios XI servers. Our install of Red Hat is supported through SUSE and using Spacewalk for updates. Because of this, it appears that any Nagios XI install/upgrade fails the checks for the Red Hat rpm's (rpm -q redhat-release || rpm -q redhat-release-server).
Is there a step by step guide to getting around this? It is a bit problematic for us to have to manually edit the install files each time and then also edit our xi-sys.cfg file multiple times to get rid of improperly formatted version info.
Examples for version from get-os-info:
$ sed 's/.*release \([0-9.]\+\).*/\1/' /etc/redhat-release
7.6
7.6
# The above "Red Hat Enterprise Linux Server" string is only used to
# keep software compatibility.
RPM checks:
$ rpm -q redhat-release-server
package redhat-release-server is not installed
package redhat-release is not installed
$ cat /etc/redhat-release
Red Hat Enterprise Linux Server release 7.6 (Maipo)
# This is a "SLES Expanded Support platform release 7.6"
npolovenko
Re: Nagios XI Install/Upgrade issues
Post by npolovenko »
Hello, @hbouma. We only support installations on a clean OS without any third party integrations. The only solution to fix this would be to manually change the installation scripts or start with a new RHEL server.
