These websites are hosted in azure and don't allow pings. Based on several forum posts i've modified the check commands, as well as edited the default template, but now i'm stumped. Can anyone help me remove the ping status check?
Here is my config.
define host {
name web-server ; The name of this host template
use generic-host ; Inherit default values from the generic-host template
check_period 24x7 ; By default, Windows servers are monitored round the clock
check_interval 5 ; Actively check the server every 5 minutes
retry_interval 1 ; Schedule host check retries at 1 minute intervals
max_check_attempts 10 ; Check each server 10 times (max)
check_command check_tcp!443 ; Default command to check if servers are "alive"
notification_period 24x7 ; Send notification out at any time - day or night
notification_interval 60 ; Resend notifications every 30 minutes
notification_options d,r ; Only send notifications for specific host states
contact_groups admins ; Notifications get sent to the admins by default
hostgroups websites ; Host groups that Windows servers should be a member of
register 0 ; DON'T REGISTER THIS - ITS JUST A TEMPLATE
retain_status_information 0
retain_nonstatus_information 0
define host {
use web-server ; Inherit default values from a template
host_name beacon.domain.com ; The name we're giving to this host
alias Beacon ; A longer name associated with the host
address beacon.domain.com ; IP address of the host
hostgroups websites
service_description check_beacon_certificate
check_command check_http! --ssl -p 443 --sni -C 90,14 -u https://beacon.domain.com/login///
service_description check_beacon_website
check_command check_http! -u https://beacon.domain.com/login/// -p 443 -w 400 -c 5000 --ssl --sni
