Hello guy,
I was wondering if I needed a RAMdisk for our environment since the web interface is sometime a little bit slow. 4-10 sec waiting.
I did yesterday upgrade the max SQL connection to 500 which help. But I was wondering if the ramdisk would be help for that situation even if the latency does not look so bad.
Was also wondering if we need to do a script to backup and restore everything on it upon restart. Or it's handle by the OS/Service.
Don't want to end up with a not working environment.
Thank you guys.
Monitoring Engine Performance
Host Check Latency
Min 0.00 sec
Max 0.17 sec
Avg 0.00 sec
Host Check Execution Time
Min 0.00 sec
Max 10.01 sec
Avg 0.42 sec
Service Check Latency
Min 0.00 sec
Max 1.01 sec
Avg 0.01 sec
Service Check Execution Time
Min 0.00 sec
Max 34.36 sec
Avg 1.22 sec
Active Host Checks
1-min 611
5-min 1,213
15-min 1,213
Active Service Checks
1-min 737
5-min 2,930
15-min 5,761
Load
1-min 2.28
5-min 2.58
15-min 2.53
CPU Stats
User 19.01%
Nice 0.00%
System 5.70%
I/O Wait 0.10%
Steal 0.00%
Idle 75.19%
Needed Ramdisk?
Re: Needed Ramdisk?
Hey,
My personal advice is, if you have half a GB of memory spare, to set up the ramdisk anyway. It helps and is not that hard to set up, just follow the official instructions. You'll have to do it eventually, why not enjoy the benefits now. We assigned it 500 MB which is only used 13 % atm:
Grtz
Willem
tmpfs 500M 63M 438M 13% /var/nagiosramdiskWillem
Nagios XI 5.8.1
https://outsideit.net
Re: Needed Ramdisk?
I have to agree with @WillemDH, if you have the available memory, it would be beneficial to do it nowWillemDH wrote:My personal advice is, if you have half a GB of memory spare, to set up the ramdisk anyway. It helps and is not that hard to set up, just follow the official instructions. You'll have to do it eventually, why not enjoy the benefits now.
https://assets.nagios.com/downloads/nag ... giosXI.pdf
