How to manage SLA
Frédéric GRANAT
How to manage SLA
Post by Frédéric GRANAT »
Assuming the SLA is 3 days to restore the availability of a service.
I'm using operation center to monitor services in critical state.
In the operation center, I've got a column "duration" but no information about the SLA.
I need to have the information about the time remaining before the SLA limit is reached.
Is it possible and how ?
cdienger
Re: How to manage SLA
Post by cdienger »
The OC component and code can be found under Admin > System Extensions > Manage Component. It looks like relies on the status.php which I believe is what needs to be updated to get the information you'd like to see. It currently isn't coded in but I can submit a feature request on your behalf if you'd like. Please keep in mind that the decision to implement the enhancement is at the discretion of our development team.
Frédéric GRANAT
OK thanks, you can close the post.
Frederic
benjaminsmith
Post by benjaminsmith »
Hi Frederic,
Thanks for the update. Closing.
