Hello All,
I am running NSClient++ version 5.2 on our front end Exchange 2010 servers running on 2008r2. I found this helpful article https://docs.nsclient.org/howto/counters/
When I run the following command on both servers I get very different results
C:\Program Files\NSClient++>nscp sys -- --list --all
Server #7 will find 1900 counters. Server #8 will find 40,000 counters.
Any recommendations on why there is such a difference would be appreciated. This broke several of my checks.
Thank you
Ryan
NSClient++ Counters missing
Re: NSClient++ Counters missing
Different server have different performance counters depending on what software is installed on the server.. For example, a web server has a bunch of performance counter for each W3svc instance
I apologize for not being clear. Both servers in question are solely Exchange 2010 front end servers. It is just very odd to see such a difference.scottwilkerson wrote:Different server have different performance counters depending on what software is installed on the server.. For example, a web server has a bunch of performance counter for each W3svc instance
Thank you
I guess all I can suggest would be to fave each list to a file and then compare them to see where they differ.
