cdienger wrote:Creating new filters is an option. How to do this really depends on how the logs vary and what data you'd like to extract. You could for example extract the next field after the mac address if you wanted or ignore it if it's blank or didn't meet the filter requirement:
grok {
match => { "message" => "^%{INT:number},%{DATE:date},%{TIME:time},%{WORD:mtype},%{IP:ip},%{HOSTNAME:computername},%{BASE16NUM:mac},(%{INT:anothernumber})?"}
This would create all the same fields from the previous example, but would create an additional field(anothernumber) if the next field contained an integer.
I am struggling with this new one now and few questions about it
232 <134> 2019-04-17T23:01:39+08:00 PulseSecure: 2019-04-17 23:01:39 - kc-ssl-apac-node1 - [222.65.214.176] yanxia(KC password authentication)[KC Users Secure PW] - VPN Tunneling: Session ended for user with IPv4 address 10.106.12.92
OR
240 <134> 2019-04-17T23:15:36+08:00 PulseSecure: 2019-04-17 23:15:36 - kc-ssl-apac-node1 - [47.31.84.174] kaushas(KC token authentication)[KC Users Secure Pulse] - VPN Tunneling: User with IP 10.106.10.105 connected with ESP transport mode.
match => { "PulseSecure" => "%{DATE:date} %{TIME:time} %{WORD:mtype} %{IP:ip} ..
- How to deal with "space" instead of "," in between fields ?
- How to omit unwanted fields ?
- How to figure required fields format ?
This is what is needed: 2019-04-17 23:01:39 - kc-ssl-apac-node1 IP - yanxia - [KC Users Secure PW] - Message
- yanxia is a user name
- We onyl need (KC token authentication) OR [KC Users Secure Pulse]
- IP is an external IP
- Message is a full message in the end of the operation
