We experienced an issue over the weekend where some of our Exchange servers CPUs were pegged above 90% but we were not alerted by Nagios XI. Upon initial inspection, it appears that Nagios XI is reporting CPU Load as roughly 20-25% lower than what the server is reporting on itself.
Please see attached screen shots.
It looks like the check is on a 5 minute interval which might explain the lack of reporting, but this server had it's CPU running at over 90% for almost 3 days. Even now it's getting up to 80-85% without ever reporting even a warning status.
Is there another check we could be using or maybe a different way to get more accurate reporting?
Thank you.
CPU Checks not reporting accurately
Re: CPU Checks not reporting accurately
This is what the current check is doing
If not, it will not send an email notification.
The default setting is 5 minutes.
It is an Averaged check. The server has to be running over the threshold for the full timeperiod that the check is running to generate an email Notification.CPULOAD =
Average CPU load on last x minutes.
Request a -l parameter with the following syntax:
-l <minutes range>,<warning threshold>,<critical threshold>.
<minute range> should be less than 24*60.
Thresholds are percentage and up to 10 requests can be done in one shot.
ie: -l 60,90,95,120,90,95
This can be locked, thank you.
