Hi Team,
I gone through the nagios XI HA but we have no any option from NagiosXI console.
We have option backup and restoration and some other options. By using backu and restoration it is not safe and difficult to understand.
My suggestion if we have HA from Nagios XI console it is very easy to understand. We will create HA from Primary to secondary so that it is easy to handle also.
We have loose two customer because of only which we don't have HA in NagiosXI.
Please correct me if i am wrong.
Nagios XI high availability
benjaminsmith
Re: Nagios XI high availability
Hi @grayloglearn,
Thank you for your feedback. Yes, that type of functionality is currently not available from the Nagios XI console. The recommended solution is to use a service like Linbit. Please see the documentation below.
HA Nagios XI v5 Cluster on RHEL7
https://www.linbit.com/en/576-ha-nagios ... -on-rhel7/
Nagios XI - How To Achieve High Availability
grayloglearn
We have a lot of tools which is having default HA ,
Sincier request is create the inbuilt HA from nagios console only so that it will helpfull us.
benjaminsmith
Hello @grayloglearn,
Noted. I will let the development team know.Sincier request is create the inbuilt HA from nagios console only so that it will helpfull us.
