extract list of all available hosts in nagiosxi
qtg_tech
Post by qtg_tech »
Dear Support,
Could you please suggest how I can extract list of all available hosts groups/host/host + services or only services into CSV file.
Installed Version: 5.4.13
Thank you in advance
Re: extract list of all available hosts in nagiosxi
There isn't a way to get them through the UI but you can get them out of the database with a command like the following
echo 'select CONCAT(name1,",",name2) as "host,service" from nagios_objects where objecttype_id in (1,2) AND is_active=1 and name1 != "";'|mysql -pnagiosxi nagios
