Temperature report
Kujab
Temperature report
Post by Kujab »
I'm monitoring temperature in some refrigerators. Alarms are working fine, but I need to create reports (weekly, monthly, ad-hoc) with charts and all collected values. Also with max/min and avg values. How to achieve that ?
Thank you for your help.
Best regards
Jakub Hauzner
Re: Temperature report
With Nagios XI Enterprise edition, you could schedule a page as a report. Try the following:
1. Create a dashboard for your temperature graphs (Dashboards > New Dashboard)
2. Go to Home > Service Status > <your service> > Performance Graphs tab, and click on the "dashify" icon in order to add the graph to your dashbaord
3. To to your dashboard, and click on the "Schedule page" icon on the upper right to schedule a report
Note: This should look the same on your system with the exception of the colors. Mine are dark as I am testing a dark theme, and forgot to switch it back to the "default". :)
Kujab
Post by Kujab »
Thank you for your reply, but I need also table with values, not only chart.
Is that possible ?
Unfortunately, it is not possible to create such a report at this time. You could download (save) the chart values in a CSV format by clicking on the "Chart context menu" in the upper right corner of the graph (the 3 horizontal lines), and selecting "Download CSV". Then, you can email the report to whoever needs it. You will have to do it manually though.
