3 simple questions regarding your use of nagios
feron
Post by feron »
Hi everyone,
for my bachelor thesis I'm working on a mobile frontend for nagios. I would really appreciate it if you could answer some questions for me :)
How (and how often) do you interact with nagios? (Push, email, app, web, ...)
When interaction with nagios, what works good for you and how could the interaction be improved?
How many people other people are using nagios with you? If more than one, how does communication work?
Feel free to answer only one question, interpret them in a way that seems more reasonable for you or simplify your answers. Anything helps, thanks for tanking the time :)
Cheers,
Mike
swolf
Re: 3 simple questions regarding your use of nagios
Post by swolf »
Hi Mike,
Thanks for taking interest! If you're looking for a larger community of Nagios Core users, you might have better luck taking a look at our subreddit.
When you finish your frontend, you could also consider publishing it on the Exchange.
