DHCP Monitoring
DHCP Monitoring
Want to set up a DHCP monitoring and alerts to view in the nagios core GUI. Will any of these work and can you please show step by step process on the steps to get this working new to this. Any help is greatly appreciated. The nagios core is running on centos and the Dhcp is windows.
https://exchange.nagios.org/directory/P ... sh/details
https://exchange.nagios.org/directory/P ... pe/details
Re: DHCP Monitoring
Quick question. The first plugin runs on the nagios server and requires the host you are checking to have SNMP enabled and the second one is a Visual Basic script that runs on a Windows server using the NSClient++ agent, which one do you want to use?
Re: DHCP Monitoring
We can try the snmp for now to see how that alerts or you whatever your think would work the easiest.I am good either way. Thanks for response.Will they both show metrics in the nagios GUI?tgriep wrote:Quick question. The first plugin runs on the nagios server and requires the host you are checking to have SNMP enabled and the second one is a Visual Basic script that runs on a Windows server using the NSClient++ agent, which one do you want to use?
Re: DHCP Monitoring
First, install and configure SNMP on the Windows server. You can search Microsoft for instructions for doing that.
The plugin requires Net-SNMP to be installed on the Nagios server, install that.
Download the plugin and put it in the /usr/local/nagios/libexec folder and call it check_dhcp_all_pools.sh and make is executable.
Create a command for it in the commands.cfg file line this example.
An example service is below. It uses $ARG1$ as the SNMP Community string. $ARG2$ as the warning threshold. $ARG3$ as the critical threshold.
If you view the plugin, is has a bit more details in it.
I don't have access to a Windows DHCP server so I can't show you the plugin's output but it says that it will show the total amount of scopes available vs those shown.
command_name check_dhcp_all_pools
command_line $USER1$/check_dhcp_all_pools.sh $HOSTADDRESS$ $ARG1$ $ARG2$ $ARG3$
}An example service is below. It uses $ARG1$ as the SNMP Community string. $ARG2$ as the warning threshold. $ARG3$ as the critical threshold.
host_name WindowsHost
service_description Check DHCP
use local-service
check_command check_dhcp_all_pools!public!20!30!!!!!
max_check_attempts 5
check_interval 5
retry_interval 1
notification_period 24x7
notification_options w,c,u,r,s,
notifications_enabled 1
contacts nagiosadmin
register 1
}I don't have access to a Windows DHCP server so I can't show you the plugin's output but it says that it will show the total amount of scopes available vs those shown.
Re: DHCP Monitoring
tgriep wrote:First, install and configure SNMP on the Windows server. You can search Microsoft for instructions for doing that.
define command { command_name check_dhcp_all_pools command_line $USER1$/check_dhcp_all_pools.sh $HOSTADDRESS$ $ARG1$ $ARG2$ $ARG3$ }
An example service is below. It uses $ARG1$ as the SNMP Community string. $ARG2$ as the warning threshold. $ARG3$ as the critical threshold.If you view the plugin, is has a bit more details in it.Code: Select all
define service { host_name WindowsHost service_description Check DHCP use local-service check_command check_dhcp_all_pools!public!20!30!!!!! max_check_attempts 5 check_interval 5 retry_interval 1 notification_period 24x7 notification_options w,c,u,r,s, notifications_enabled 1 contacts nagiosadmin register 1 }
Ok going to try this now standby thank you.
Re: DHCP Monitoring
What about the Visual basic install using nsclient?
Re: DHCP Monitoring
For instructions on installing NSClient++, you can find it on the NSClient++ web site.
http://nsclient.org/
You would have to create an external command in the NSClient's config file for the visual basic script. Details on how to do that.
https://docs.nsclient.org/reference/che ... alScripts/
Then, you would have to use the check_nrpe plugin to connect to the Windows system running NSClient++
At the bottom in this article are the instructions for Install check_nrpe Plugin Only.
https://support.nagios.com/kb/article.php?id=515
Your server may already the check_nrpe plugin installed so check for that.
Or, you can use NCPA instead of NSClient++ and some details on that are at these links.
https://assets.nagios.com/downloads/nag ... ndows.html
https://www.nagios.org/ncpa/
Re: DHCP Monitoring
So my question is both the plugins will show details from the GUI in Nagios right?
Re: DHCP Monitoring
Can you please explain in detail on how to get this work with the nrpe? seems to be not pulling any information. Do i need to follow the same process for NRPE as ncpatgriep wrote:For instructions on installing NSClient++, you can find it on the NSClient++ web site.
