vasilij
Posts: 3 Joined: Wed Mar 06, 2019 7:54 am
Post
by vasilij » Thu Apr 11, 2019 4:24 am
Nagios Agent on Windows7 return an error:
UNKNOWN: Error occurred while running the plugin. Use the verbose flag for more details.
I have that error only with Process Count. CPU Usage and Memory Usage working as well.
NCPA client version is 2.1.6
check_ncpa.py plugin version is 1.1.5
Firewall is also turned off on client PC
Can you help me?
vasilij on Fri Apr 12, 2019 2:54 am, edited 1 time in total.
Posts: 19396 Joined: Tue Nov 15, 2011 3:11 pm
Post
by scottwilkerson » Thu Apr 11, 2019 3:21 pm
Can you show what command is being run?
Have you tried running the command from the CLI?
vasilij
Post
by vasilij » Fri Apr 12, 2019 2:40 am
HI Scott,
Thanks for fast answer.
Yeap, I have tried:
Post
by scottwilkerson » Fri Apr 12, 2019 8:43 am
Can you run this from the CLI and show the output
curl -k "https://172.16.6.56:5693/api/processes?check=true&warning=150&critical=200&token=hibike" -vvv
Also can you attach your ncpa.cfg from the client server, also the logs from
C:\Program Files (x86)\Nagios\NCPA\var\log
vasilij
Post
by vasilij » Fri Apr 12, 2019 9:08 am
That's the output:
* Trying 172.16.6.56...
* TCP_NODELAY set
* connect to 172.16.6.56 port 5693 failed: Verbindungsaufbau abgelehnt
* Failed to connect to 172.16.6.56 port 5693: Verbindungsaufbau abgelehnt
* Closing connection 0
curl: (7) Failed to connect to 172.16.6.56 port 5693: Verbindungsaufbau abgelehnt
itops@vsr19-003:~$ curl -k "https://172.16.6.56:5693/api/processes?check=true&warning=150&critical=200&token=hibike" -vvv
* TCP_NODELAY set
* Connected to 172.16.6.56 (172.16.6.56) port 5693 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
* ALPN, server did not agree to a protocol
* Server certificate:
* subject: C=US; ST=Minnesota; L=St. Paul; O=Nagios Enterprises, LLC; OU=Development; CN=PC14-015
* start date: Apr 12 13:58:31 2019 GMT
* expire date: Apr 9 13:58:31 2029 GMT
* issuer: C=US; ST=Minnesota; L=St. Paul; O=Nagios Enterprises, LLC; OU=Development; CN=PC14-015
* SSL certificate verify result: self signed certificate (18), continuing anyway.
> GET /api/processes?check=true&warning=150&critical=200&token=hibike HTTP/1.1
> Host: 172.16.6.56:5693
> User-Agent: curl/7.58.0
> Accept: */*
< HTTP/1.1 500 INTERNAL SERVER ERROR
< Content-Type: text/html; charset=utf-8
< Content-Length: 2225
< Date: Fri, 12 Apr 2019 13:59:55 GMT
<!DOCTYPE html>
<html lang='en'>
<head>
<title>Page Not Found · NCPA</title>
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<meta name="description" content="NCPA Web Interface">
<meta name="author" content="Nagios Enterprises, LLC">
<link rel="shortcut icon" type="image/png" href="/static/img/ncpa.png" />
<link rel="icon" type="image/png" href="/static/img/ncpa.png" />
<link rel='stylesheet' href='/static/css/bootstrap.min.css'>
<link rel='stylesheet' href='/static/css/font-awesome.min.css'>
<link rel='stylesheet' href='/static/css/ncpa.css'>
<script src='/static/js/jquery.2.2.4.min.js'></script>
<script src='/static/js/bootstrap.min.js'></script>
<script src='/static/js/d3.v4.min.js'></script>
<script src='/static/js/main.js'></script>
</head>
win32service_ncpalistener.log
(65 Bytes) Downloaded 207 times
ncpa_listener.log
(2.49 KiB) Downloaded 225 times
ncpa.cfg
(7.91 KiB) Downloaded 235 times
