NagiosXI API system/scheduleddowntime author parameter
wbaars
Post by wbaars »
Since we upgrade our Nagios XI to 5.5, I'm trying to use the API to set scheduleddowntime.
I can schedule a downtime (via Powershell) correctly by using an API Key, but when I use the API Key from a special created admin account, and set the "author" parameter, the author for the downtime (in the webui and API) is still the user the API key belongs to.
A small piece of my Powershell code:
$author = "exampleuser"
$uri = "http://$nagsrv/nagiosxi/api/v1/system/scheduleddowntime?apikey=$apikey"
$body = "author=$author&comment=$comment&all_services=1&duration=$duration&start=$starttime&end=$endtime&hosts[]=$hostname"
$downtimejson = Invoke-RestMethod -Uri $uri -Method Post -Body $body
Has anyone seen this before? Is there a way to get this working? Or am I doing something wrong?
PS: We have a licensed NagiosXI install, but cannot post in the Customer section on this forum.
Re: NagiosXI API system/scheduleddowntime author parameter
Is "exampleuser" an actual username of a user on your system? It must match a username exactly
Actually looking into this, it does appear to be a bug.
I am submitting a bug report to get this resolved in a future release
wbaars
Post by wbaars »
Thanks for looking into this issue. Happy it's not my fault :)
My script retrieves the correct username from the system, the username does match.
wbaars wrote:Thanks for looking into this issue. Happy it's not my fault :)
This should be resolved in the next release of Nagios XI
wbaars
Post by wbaars »
I updated last week, and verified this issue is solved in NagiosXI 5.6.1.
Thanks!
wbaars wrote:I updated last week, and verified this issue is solved in NagiosXI 5.6.1.
Thanks!
Great!
Locking thread
