Alarm notifications
HaschkeD
Alarm notifications
Post by HaschkeD »
i use Nagios Core 3.2.3 with NagiosQL 3.1.1.
We set alarm notifications in the host. If a service of the host is down we get a notification. Is it possible to set an exception only for one service?
Regards
Dennis
Re: Alarm notifications
Do you mean you don't want to send notifications for that service?
If so you would set the following in that services configuration
notifications_enabled    0
HaschkeD
Post by HaschkeD »
i will send notification for that service….but other than for the host.....
HaschkeD wrote:Hi,
I don't understand what you mean
HaschkeD
Post by HaschkeD »
i think i found a solution….
In german:
Nagios Services erben ihre Kontakte von ihrem jeweiligen Host.
Aber nur dann, wenn für den Service selbst keine Kontakte hinterlegt sind.
Wenn Meldungen also nicht mehr an xxx schicken möchte, muss er nur für diesen Service explizit xxx als Kontakt definieren.
Regards
Dennis
HaschkeD wrote:Hi,
In german:
Regards
Dennis
Translated in English
Nagios services inherit their contacts from their respective hosts.
But only if there are no contacts for the service itself.
So if messages do not want to send to xxx anymore, they just need to explicitly define xxx as a contact for this service.
