Hi all,
I am trying to install the NSCP-0.5.2.3.5-x64 msi on several windows servers. It will be installed via chef, but I still need to provide the correct install command. I am trying to install the msi with a specific ini file.
As of right now, my command looks like this
$webinstallerpath = "C:\Users\svc.test\Desktop\nsclient\NSCP-0.5.2.35-x64.msi"
$arguments = "/i $webinstallerpath CONF_CAN_CHANGE=`"True`" ALLOWED_HOSTS=`"10.x.x.x`" NSCLIENT_PWD=`"`" CONF_CHECKS=`"True`"CONF_NSCLIENT=`"True`" /norestart"
Start-process msiexec.exe -ArgumentList $arguments -Wait
I have been unable to locate the command to pass the ini file(which is in the same folder as the install)
Any help would be appreciated. Thanks in advance
NSClient install on Windows
benjaminsmith
Re: NSClient install on Windows
Hi @sanzen,
We currently do not produce documentation for installing NSClient++ using configuration management software like Chef. Have you checked their site for documentation or the forums for assistance.
https://supermarket.chef.io/cookbooks/nscp
Let us know if you're able to get it working.
