[1555110063] Caught SIGTERM, shutting down...
[1555110063] Successfully shutdown... (PID=17713)
[1555110063] ndomod: Shutdown complete.
[1555110063] Event broker module '/usr/local/nagios/bin/ndomod.o' deinitialized successfully.
I have a local backup [backs up to a mounted NFS share] that happens at 12:01am. Could it be related?
Is there a list of what to monitor for these, so I can monitor it from the other DC?
Monitoring Engine
Performance Grapher
Database Backend
Database Maintenance
Command Subsystem
Event Manager
Feed Processor
Report Engine
Cleaner
Nonstop Operations Manager
System Statistics
Monitoring Engine stopped over the weekend
Re: Monitoring Engine stopped over the weekend
Never mind. Seems someone had removed a node and never applied the config, so the node still existed in one of the hostgroups.
If you can let me know the easiest way to monitor the above from a different XI node, that would be great.
You can monitor one XI server from another using the "Nagios XI Server Wizard"bomahony wrote:Never mind. Seems someone had removed a node and never applied the config, so the node still existed in one of the hostgroups.
