Hello Team,
We are Getting following error while installing NRPE agent on Suse Linux 12 SP3:
linux-:/tmp/linux-nrpe-agent # ./fullinstall
Nagios Linux Agent Installer
This script will install the Nagios Linux Agent by executing all necessary
sub-scripts.
IMPORTANT: This script should only be used on a clean installed system:
RedHat Enterprise, CentOS, Fedora, Cloud Linux or Oracle
OpenSUSE or SUSE Enterprise
Ubuntu or Debian
Do NOT use this on a system running any other distro or that
does not allow additional package installation.
Do you want to continue? [Y/n] y
Proceeding with installation...
Running './0-repos'...
Configuring Repos...
Enabling SUSE SDK ...
Please register your system using the --regcode parameter, or provide the --url parameter to register against SMT.
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-repos'
linux-6kdw:/tmp/linux-nrpe-agent # linux-6kdw:/tmp/linux-nrpe-agent # ./fullinstall
-bash: linux-6kdw:/tmp/linux-nrpe-agent: No such file or directory
linux-6kdw:/tmp/linux-nrpe-agent # ============================
If '============================' is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf ============================
Please find the attached screenshot for more detail
NRPE agent installation error on Suse Linux 12 SP3(x64)
Re: NRPE agent installation error on Suse Linux 12 SP3(x64)
Is this sytem properly registered? Can you show us the output of the following command?
Also, upload the entire "install.log" on the forum.
SUSEConnect --status-textBe sure to check out our Knowledgebase for helpful articles and solutions!
Hello Team,
The output of command "SUSEConnect --status-text" is as below,
linux-6:~ # SUSEConnect --status-text
Installed Products:
SUSE Linux Enterprise Server 12 SP3
(SLES/12.3/x86_64)
Not Registered
also output of install.log file is as below,
Nagios Linux Agent Installation Log
DATE: Thu Mar 21 16:08:25 +03 2019
DISTRO INFO:
SUSE
12.3
x86_64
DATE: Thu Mar 21 16:13:28 +03 2019
DISTRO INFO:
SUSE
12.3
x86_64
DATE: Fri Mar 22 11:59:16 +03 2019
DISTRO INFO:
SUSE
12.3
x86_64
DATE: Tue Apr 16 16:59:51 +03 2019
DISTRO INFO:
SUSE
12.3
x86_64
"install.log" 48L, 1188C
Please find the attached screenshot for more detail. Please do the needful.
Installed Products:
(SLES/12.3/x86_64)
Not Registered
DISTRO INFO:
SUSE
12.3
x86_64
DISTRO INFO:
SUSE
12.3
x86_64
DISTRO INFO:
SUSE
12.3
x86_64
DISTRO INFO:
SUSE
12.3
x86_64
The linux agent won't install an a system that is not registered. Please register your system, and rerun the fullinstall script.linux-6:~ # SUSEConnect --status-text
Installed Products:
(SLES/12.3/x86_64)
Not Registered
Hello Team,
Could you please tell us how we can register a system ?(SUSE Linux Enterprise Server 12 SP3)
This is out of scope of nagios support, but you can check this out:
https://www.suse.com/support/kb/doc/?id=7016626
or contact their support in order to find out how to register the system.
