Hi there,
Today I started to see problems with the Event Manager, the check status of this service is flapping and the logs /usr/local/nagiosxi/var/eventman.log and /usr/local/nagiosxi/var/event_handler.log are writing really fast and can't see the error or the cause of it.
The event manager status is flapping
neo_infraestructura
neo_infraestructura
Re: The event manager status is flapping
The event_handler.log it's been written really fast. It size was of 60gb and filled my /usr disk space, I already had made a repair of the database and a reboot of the machine but the problem persist.
The version of NagiosXI that I have is the 5.5.10.
neo_infraestructura
Now the disc / was fulled due to a file in the mysql folder /var/lib/mysql/nagiosxi/ and found that the xi_meta are really heavy.
Then I tryed to make another database repair and it got stuck in this the repair of nagiosxi
What is going on?
What is going on?
It looks like you're running to bug from a couple versions ago. Clear out the table(and a couple others than can cause issues):
and then reboot the server to stop and start everything for good measure.
echo "truncate table xi_events; truncate table xi_meta; truncate table xi_eventqueue;" | mysql -u root -pnagiosxi nagiosxiAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
neo_infraestructura
It took a while, but the command worked. I have rebooted the machine and then stopped and started all the services. Everything seems to be working fine. I'm only worried that I still don't know what was the problem. I will be monitoring the status of the server.
Please don't close the topic yet.
Sounds good, we will leave the topic open.neo_infraestructura wrote:It took a while, but the command worked. I have rebooted the machine and then stopped and started all the services. Everything seems to be working fine. I'm only worried that I still don't know what was the problem. I will be monitoring the status of the server.
