I was wondering if there is an easy way to get a report of all child relationships (hosts) for a parent host. For example, I want to generate a list of every device (host) connected to a switch. All of the hosts are entered correctly but we have so many, I am trying to simply get a list of all child devices off a single switch. I tried using the Hypermap but we have too many devices.
Thank you,
Shane
Report on child relationships
Re: Report on child relationships
This should do the trick(replace 'localhost' with the actual parent host):
echo "select nagios_hosts.display_name from ((nagios_objects INNER JOIN nagios_host_parenthosts ON nagios_objects.object_id=nagios_host_parenthosts.parent_host_object_id)INNER JOIN nagios_hosts ON nagios_host_parenthosts.host_id = nagios_hosts.host_id) where nagios_objects.name1='localhost';" | mysql -uroot -pnagiosxi -DnagiosAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Thank you for the code and I apologize for the following newbie question, but where do I run that from? The SSH console?
Yes, run it from the command line of the XI machine.
Thank you so much! That worked perfectly!
Glad to hear!
