scheduleddowntime without admin api token?
jaimie.livingston
Post by jaimie.livingston »
Is there a way to utilise the scheduleddowntime API (create and delete) in automation scripts that does NOT require an Admin level API token?
And, may I suggest an Incident/Maintenance API that allows management of scheduled downtime, acknowledgements, adding comments, enabling/disabling notifications, enabling/disabling active and passive checks, and the like, specifically tailored for automation such that the API does NOT require admin access.
Jaimie Livingston
cdienger
Re: scheduleddowntime without admin api token?
Post by cdienger »
It looks like admin level authorization is a requirement for this. I'll file a feature request for this and your other suggestions. Please keep in mind that the decision to implement the enhancement is at the discretion of our development team.
