Monitor SHMALL value
anthonywong
Post by anthonywong »
Hi Support,
There is a request came in to monitor "SHMALL" value. Is this possible for Nagios?
Following is SHMALL in Linux box:
a1383660@HKLPAPISI005[~] $ lsipc
RESOURCE DESCRIPTION LIMIT USED USE%
MSGMNI Number of message queues 1024 1 0.10%
MSGMAX Max size of message (bytes) 131072 - -
MSGMNB Default max size of queue (bytes) 131072 - -
SHMMNI Shared memory segments 4096 39 0.95%
SHMALL Shared memory pages 2097152 198537 9.47%
SHMMAX Max size of shared memory segment (bytes) 68719476736 - -
SHMMIN Min size of shared memory segment (bytes) 1 - -
SEMMNI Number of semaphore identifiers 1024 32 3.12%
SEMMNS Total number of semaphores 256000 32 0.01%
SEMMSL Max semaphores per semaphore set. 500 - -
SEMOPM Max number of operations per semop(2) 250 - -
SEMVMX Semaphore max value 32767 - -
Thanks and Regards,
Anthony
Re: Monitor SHMALL value
You will need to write a custom script by following the Nagios Plugins Development Guidelines.
Here's a "sample" script that can get you started.
SHMALL.sh
#!/bin/bash
output=`lsipc | grep SHMALL | awk '{print $6}'`
warn=$1
crit=$2
if [ $output -gt $crit ]; then
  echo "CRITICAL: Shared memory pages: $output | 'Used'=$output;$warn;$crit"
  exit 2
elif [ $output -gt $warn ]; then
  echo "WARNING: Shared memory pages: $output | 'Used'=$output;$warn;$crit"
  exit 1
else
  echo "OK: Shared memory pages: $output | 'Used'=$output;$warn;$crit"
  exit 0
fi
Place the script into the nagios plugins directory, and create a command in the nrpe.cfg file, for example:
command[check_SHMALL]=/usr/local/nagios/libexec/SHMALL.sh $ARG1$ $ARG2$
Save, exit and restart NRPE, so that changes can take effect.
Test the check by running the following command from the command line on the Nagios server:
/usr/local/nagios/libexec/check_nrpe -H <client ip> -c check_SHMALL -a <warning> <critical>
where you substitute <warning> and <critical> with actual values for warning and critical thresholds.
Note: In the example above, I am looking into the "USED Shared memory pages". If you wanted to monitor "USE%" instead, you would need to modify the script.
Hope this helps.
anthonywong
thanks for your assistance and pointer.
You are welcome! Let us know if it is OK to close this topic. Thank you!
