Error running backup_xi.sh script
Sampath.Basireddy
Post by Sampath.Basireddy »
Am getting below error when running backup_xi.sh script. Please help!!
Backing up NagiosQL...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/share/perfdata/brpsssotst01.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/int01aumsint01.ux.corp.local/Main_Memory_Usage.rrd: file changed as we read it
tar: /usr/local/nagios/share/perfdata/int01aumsint01.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/brmsappcaa21.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/brpsappqec2.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/stg01brmsapp01.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/brmsapppre20.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/stg01brmsint01.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/qen02brwfaapp01.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/breaappqeb1.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/val01brmsben02.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/qen01brwfaapp01.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/bratappsb1.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/brgswebcab2.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/pre01brmsmsg04.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/vbrdbs29.ux.corp.local/Load.rrd: file changed as we read it
tar: /usr/local/nagios/share/perfdata/vbrdbs29.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/vbrdbs26.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/brfrwebcaa2.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/oxddev1-scan.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/share/perfdata/slejappls1.ux.corp.local: file changed as we read it
tar: /usr/local/nagios/nagiosxi/var/event_handler.lock: File removed before we read it
tar: /usr/local/nagios/nagiosxi/var/eventman.log: file changed as we read it
tar: /usr/local/nagios/nagiosxi/var: file changed as we read it
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
Copying ramdisk configuration...
Backing up Nagios XI...
Backing up MRTG...
Backing up the SNMP trap interface configuration files...
Backing up NRDP...
Backing up Nagvis...
Backing up MySQL databases...
mysqldump: Got error: 144: "Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed" when using LOCK TABLES
Error backing up MySQL database 'nagios' - check the password in this script!
Sampath.Basireddy
Re: Error running backup_xi.sh script
Checked the passwords as suggested in a different post:
root@nagios1:[/store/mysql/nagiosxi]: mysql -uroot -pnagiosxi
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 4720828
Server version: 5.5.60-MariaDB MariaDB Server
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> quit
Bye
root@nagios1:[/store/mysql/nagiosxi]: mysql -unagiosxi -pn@gweb
Your MariaDB connection id is 4720850
MariaDB [(none)]> Ctrl-C -- exit!
Aborted
root@nagios1:[/store/mysql/nagiosxi]: mysql -undoutils -pn@gweb
Your MariaDB connection id is 4720853
Aborted
root@brnagios1:[/store/mysql/nagiosxi]:
Also, the disk has enough space:
root@nagios1:[/store/mysql/nagiosxi]: df -h /store
Filesystem                    Size  Used Avail Use% Mounted on
/dev/mapper/vg_apps-lv_store   34G   21G   14G  61% /store
There is a crashed table in the database that needs to be repaired.
Run the following procedure
https://assets.nagios.com/downloads/nag ... tabase.pdf
Sampath.Basireddy
Thanks @scottwilkerson, looks good now. Please close this topic.
Sampath.Basireddy wrote:Thanks @scottwilkerson, looks good now. Please close this topic.
Great!
Locking thread
