Monitoring the connection of windows to database
shivangi
Post by shivangi »
Hi Team,
I wanted to ask if this is possible in Nagios to monitor the connection of an windows instance to a database and get alerts on the Nagios ???
I am using Nagios core version 4.4.1
Thanks in advance!!! :) :)
Re: Monitoring the connection of windows to database
If this data is stored somewhere you can write a plugin to report on it..
Here are the Nagios Plugin Development guidelines
https://nagios-plugins.org/doc/guidelines.html
