default port for nagios network analyzer
i just built and configured the nagios network analyzer to monitore netflow on my switches and while integrating it with nagios xi i was asked for the ipaddress of the network analyzer server and also a port number, am not sure what the port number is, is there a default port number am supposed to use?
Re: default port for nagios network analyzer
It just uses the web interface to connect so you can use port 80 or 443 if it's using SSL.
please see attachment of what i mean
That port can be (almost) anything. It is the port that devices will send flow data to.
See page 3 of https://assets.nagios.com/downloads/nag ... alyzer.pdf for setting up a source on NNA. Once the source is configured on NNA, you'll need to configure devices to send flow data to that port. https://assets.nagios.com/downloads/nag ... alyzer.pdf has some examples.
